clutch install problem
Old Feb 11, 2006 | 03:44 PM
97lt1z28's Avatar
Default clutch install problem
i just finished my spec stage 3 install and for some reason my clutch pedal will not move at all when i put my foot on it. This sucker is going anywhere. can someone tell me a idea of what you think is wrong. Its on a 97 lt1 by the way.thanks
Old Feb 11, 2006 | 09:28 PM
CODE4LS1's Avatar
Happened to me once......sounds like you didnt quite slide the throwout fork all the way on the unput shaft. You have to take the slave back off, somehow jar it loose and then slide it in place. Hope this helps.
