Help Quick Clutch engaging really low
Old Feb 14, 2006 | 04:49 PM
screaminbird's Avatar
Default Help Quick Clutch engaging really low
I just went to pick up my 99TA from the shop where they just put in a new CF clutch ,flywheel ,pilot bearing and upgraded oem slave. When I took it out I realized U have to put the clutch pedal to the carpet for it to disengage and even then the gears are hard to get into but when i told them it wasnt very good they told me they bled it a bunch of times and theres no more they can do. HELP ME ANY IDEAS
Old Feb 14, 2006 | 05:08 PM
JimMueller's Avatar
I wish I had the answer. I just tested mine at the shop and it's doing the same thing with the LS7 clutch and Fidanza flywheel. I told them to pull it again and put in a slave shim. So far I'm into it $880 in new parts (LS7 clutch kit, Fidanza LS2 flywheel, new master w/ drill mod, new slave, new pilot bearing) and almost $700 in labor. Soon to add another 4 hours in shop labor.
Old Feb 14, 2006 | 05:30 PM
00silver6's Avatar
i dont know if this relates to whats going on with your car.but when i put my clutch in it engaged and disengaged twards the top but about 1000 miles after it just all of a sudden started to engage about 2 ta 3 inches off the floor board ive been told to get an adjustable master cylinder but thier kinda costly. ive heard of people making there own adjustable master cylinder
Old Feb 14, 2006 | 05:35 PM
JimMueller's Avatar
For me, I had an adjustable master in the car and the shop convinced me to put a new OEM master back in because they had plenty of high HP cars without any hydarulic issues with the stock master.
Old Feb 14, 2006 | 08:13 PM
I just finished talking to the tech at centerforce they said it would have to be a bleeding problem but im still not sure if thats what it is ?
