aluminum flywheel ?
Old Mar 24, 2002 | 07:13 PM
01Hawk268's Avatar
Default aluminum flywheel ?
Does buying a aluminum flywheel really help much.
Old Mar 24, 2002 | 07:19 PM
BIGBOS's Avatar
Default Re: aluminum flywheel ?
Its a lot lighter...thats about it I think...
Old Mar 24, 2002 | 07:23 PM
01Hawk268's Avatar
It will go on a MN6 car with stock 342 gears.
Old Mar 24, 2002 | 08:15 PM
casper00'Z28's Avatar
i just installed mine about 1 month ago with a cartek clutch.lighter, less rotating, and weight makes the engine rev. quicker i could tell a diffrence in mine and everything is pretty much stock except for the rear end.no track times with it yet though.
<img border="0" alt="[Chevrolet]" title="" src="graemlins/camaro.gif" />
Old Mar 24, 2002 | 08:18 PM
that was supposed to say less rotating weight
Old Mar 25, 2002 | 03:21 PM
verbs's Avatar
I got mine in and notice that my car bogs sooo much more than it used to. Especially at the track your launches will suck IMO compared to a heavier wheel (for more inertia)
Old Mar 27, 2002 | 09:24 PM
1CAMWNDR's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
<strong>I got mine in and notice that my car bogs sooo much more than it used to. Especially at the track your launches will suck IMO compared to a heavier wheel (for more inertia)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You need to leave at a higher rpm! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[Pontiac]" title="" src="graemlins/formula.gif" />
Old Mar 27, 2002 | 10:12 PM
XtraCajunSS's Avatar
I would not recommend it without changing gears first. Your car will bog with those gears and an aluminum flywheel.
Old Mar 28, 2002 | 07:00 AM
MAFs 00 Ws6's Avatar
From what I was told when looking into an aluminum flywheel was that yes it is lighter and will rev faster, but it will also slow down a lot between shifts, therefore as much as you gain from the start evens out between shifts. Thats why I left the stock flywheel on. Than again I have no experiance with this, it was stated to me from John Stewart and a few other good sources. So all in all save the money IMO...Thanks, Michael
Old Mar 29, 2002 | 08:35 AM
Stick only's Avatar
It's all about INERTIA! read:
http://www.ramclutches.com/Clutch%20.../chapter_4.htm
Old Mar 30, 2002 | 12:03 AM
verbs's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1CAMWNDR:
<strong>You need to leave at a higher rpm! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[Pontiac]" title="" src="graemlins/formula.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">6000 rpm isn't high enough???
I need to try the trick were you hold it at 5K and right before you dump the cluch rev it up so that you dump the clutch as the revs are increasing towards ~6K rpm.....
I'll see how it works when I get some better tires.
