Post-drill mod idea,
Old Mar 2, 2006 | 11:27 PM
67RSCamaroVette's Avatar
Default Post-drill mod idea,
OK. I did the drill mod, like many of you, out there. I read that you should use fluid to push out the metal chips once you were done. I didnt want to make a huge mess, so I just got your simple rubber tipped blow gun.. like this.. , you poke it into the quick disconnect fitting, it'll open up by itself, and pull the trigger. I had a paper towel over the other end (the one that got drilled), so I could see what got blown out. Fluid was black and filled with shards of metal, even though I KNEW I got them all out. Just an idea.
Old Mar 3, 2006 | 07:08 AM
jyeager's Avatar
Thanks. I'll be doing this when I change my clutch next month.
