shift light help....
I dont know whats goin on here. I have the green to the white #10, the red to the pink wire that goes to some empty plug next to my fog light switch, and the black to a good ground. Key in the ignition, turn it to accessory, everything lights up, shift light flashed like the directions say it should. Then it goes off and stays off, set it at 2400 rpms just so i can test it w/out revving the crap out of it in the backyard, went up to 3000 and nothing! Tried it w/ the fog light switch on and off as if that had anything to do w/ it, still nothing. Why would it flash when i turn the ignition on as if its working and then not work when it hits the proper rpm? I have the 3 white switches in the correct 8cyl. position also. Dont know what else to check. Any ideas much appreciated.
