Irritating clutch problem
Old Apr 1, 2002 | 04:47 AM
99Formula's Avatar
Default Irritating clutch problem
Some of you have likely seen my wonderful "priceless" clutch burnout video. After that video was shot I went out and had a Z06 clutch and slave put in. I've been out to the track twice with the new clutch and have been plagued with problems launching. If I come off idle I have no problem and can make a full pass, nitrous and everything, and get no noticeable slip at the top end. However, when I'm running a set of sticky tires and want to come out of the hole at 3k or so the tires will stick and the clutch will go up in smoke. Around town the clutch feels fine, roll-ons are strong with no clutch slip, and engagement is about 1/2" from the top. It's just launching on sticky tires at the track that I have problems. Doesn't matter if I'm going N/A or on the bottle, a launch more than 1k above idle nukes the clutch. Any input?
Peter
p.s. While I'm on the subject, where can I get the best deal on a Ram clutch?
<small>[ April 01, 2002, 05:24 AM: Message edited by: 99Formula ]</small>
