Please HELP !
Old Mar 16, 2006 | 12:19 PM
MIGHTY z28's Avatar
Default Please HELP !
I was just out driving my car when i decide to make a test pass from a roll , i dropped in into 2nd from 4th stood on it and when it came time to shift the shifter was jammed in 2nd. I had to PUNCH the shifter out of 2nd and now i have no gears at all ! I cannot get any ! It feels like the linkage is hung or something. I cannot even find neutral ! The clutch has pressure , just no gears !
Any clue to what this may be ? Did i blow my trans up or did i just hurt the linkage ?
How hard is it to pull out ?
Old Mar 16, 2006 | 09:07 PM
wrencher's Avatar
wrencher
Sounds like the linkage inside the trans has problems. It is not real bad to get out.
I am close to you, in Montgomery. Hard to say what is wrong but I'd bet it's internal trans.
Old Mar 17, 2006 | 03:39 AM
DaddySS's Avatar
It sound like you jammed the synchro when you downshifted and then yanked the fork which is now out of the levers.
Trans is easy enough to pull and then you'll need to remove the top cover and put things back where they belong.
The trans itself is probably fine - they are pretty solid.
Old Mar 17, 2006 | 10:10 AM
MIGHTY z28's Avatar
Thanks guys.
