clutch stuck to floor
Old Mar 17, 2006 | 09:32 PM
mcamp001's Avatar
Default clutch stuck to floor
when racing. I have searched and understand the 'drill' mod, but I also found info that says this was fixed in the 01-02 models. Can anyone confirm my 01' can still have this problem, or is something else maybe the problem? I only get it at the track, after shifting into 4th at the trap, pedal stays at the floor, if i pull it back up it is ok after that.
Old Mar 18, 2006 | 12:41 AM
Redneck Z's Avatar
I did a search and found out that the 01-02's also have this problem also. I have an 02' slave and my clutch pedal sticks. The restriction is in the line and not the slave, so the new slave isn't going to help from what I understand.
Old Mar 18, 2006 | 10:04 AM
rgaynor85's Avatar
imm haveng the same problem got it at the track last night so what is the sure fix for it
