Problem with spec install! HELP!
that would be bad but if all else was taken care off...thats all i see happening
a buddy of mine did another buddys clutch and used and impact to save time and it would not go into any gear when on
If it doesn't go into reverse ever when running then it could be the reverse lockout.
The RLO is on the drivers side directly under the shifter.
A guy at Spec told me that sometimes the shim they supply isn't enough and it's necessary do add a thinner shim.
I didn't wanted to open up everything so I did the master job.
No more shifting problems after that
