BBC with LS1 t56
Old Mar 19, 2006 | 09:35 PM
cduke1780's Avatar
Default BBC with LS1 t56
Hey,
I am sure this has been covered, but I could not find my answer using the search. What do I need to bolt the Ls1 t56 to my Mark IV (old) 454. I plan to use the stock hydraulic throwout bearing set up. Could I just bolt this tranny to the block or do I need a spacer or adapter like mcleod's that is used to adapt a stock type manual clutch set-up? I guess I could mock it up and measure myself but I am sure someone else has done this.
Caleb
Old Mar 22, 2006 | 07:16 PM
cduke1780's Avatar
no answers??? ttt
Old Mar 23, 2006 | 01:19 PM
Steve01SS's Avatar
It wont be a direct swap. I havent seen it done, maybe with an adpater or something. However.. the LT1 T-56 would be a bolt on with the correct flywheel for the BBC..
Old Mar 23, 2006 | 03:26 PM
Camaroholic's Avatar
I'm probably going to use the McLeod adapter plate, the Lakewood adjustable pivot ball, and the McLeod extended pilot bearing on my 79Z. I'll fabricate or modify my own crossmember, and use my mechanical linkage. That seems to be the "least hassle" way (for my smallblock; for the bigblock, YMMV, I don't know about those).
Old Mar 28, 2006 | 09:51 PM
INFERNO's Avatar
I have a LT1 t-56 that I need the front of the LS1 T-56's parts. Let me know if you need those parts.
Old Mar 28, 2006 | 10:39 PM
Project GatTagO's Avatar
ATS has a very simple and inexpensive solution for using an LS1 T56 with a BBC. They are a sponsor and can be found at:
http://www.t56kit.com/site.html
Andrew
Old Nov 26, 2009 | 07:24 PM
jerry vair's Avatar
has any one used ATS kit with traditional BBC pressure plate and flywheel for two piece rear? The kit stated adapter and TO spacer.
