Problem after clutch install
Old Mar 20, 2006 | 01:17 PM
SLO-LSx's Avatar
Default Problem after clutch install
I recently installed a slightly used Luk clutch, resurfaced the flywheel, replaced the pilot bearing and the throwout bearing. After putting it all together and driving it for a while I was getting a horrible squeak noise comming from the trans area. I talked to my mechanic and he said it was the throwout bearing. After tearing it apart at prying the melted TO bearing off the slave and installing a new one I still have the same squeak after a couple of mins of idleing. The squeak comes and goes. Any ideas??
Old Mar 24, 2006 | 08:42 PM
SLO-LSx's Avatar
Ok I have figured out that I needed a new clutch slave. I have installed the new slave and am trying to bleed it. I have bleed for a good .5 hour. I still have no feel from the clutch pedal. Do I need to just keep bleading it? Help please.
