Slave cylinder or clutch problem?
Well, after a spirited jaunt today with the new set up (the car was driving 100% fine forever until this happened), the car suddenly became very difficult to shift, gradually getting worse until it could not engage first from idle. I hoped that I had just toasted the clutch fluid, so I came home and did a full fluid exchange and bleed. Pedal does feel solid. Start it up, it drives a few feet fine then does the same thing.... the clutch is clearly not fully releasing. If I crank the car with it in gear and the clutch down, it lurches forward. I tried bleeding a second time and went through a full bottle of fluid, same issue. So what are we thinking? Slave cylinder issue? Clutch issue?
sounds like u have air in the line
The master has not been out of the car for about a year and has run fine every day. It just suddenly stopped working.
I am not on a stock master.
