Ram Adjustable Master..what The Hell?
One other thing that I ran into was I couldn't get the end to fit on the clutch pedal with the retaining clip on. The retaining clip wouldn't fit on because the swivel joint that Ram put on there is too wide. I had to dremel the hell out of the swivel joint so the retaining clip would fit on.
I wrote little review of it a while back btw: https://ls1tech.com/forums/manual-transmission/415347-ram-adjustable-master-cylinder-install.html
