Help! This is kiiling me!
Old Apr 4, 2006 | 05:48 PM
whitedevil's Avatar
Default Help! This is kiiling me!
Ok everyone, I have been having an "issue" with selecting gears. Under high RPM acceleration, it is "hard" to get the stick in a selected gear. I can almost wait while the stick slides into gear. I installed a PRO 5.0 recently, and allthough the throws are nice, I still have this issue, what is it? I heard the 98-00 f-bod's had poor hydrolics. What could this be?
Old Apr 5, 2006 | 06:44 PM
whitedevil's Avatar
Anyone? I was told today that it was a "safeguard" All I know, is it takes allmost a full second to upshift...
Old Apr 5, 2006 | 07:13 PM
ninobrn99's Avatar
drill mod. thats all im saying...
Old Apr 7, 2006 | 08:35 PM
NVR_ENUF's Avatar
Hmmm.. will that fix it? Im having the same problem....
Old Apr 7, 2006 | 09:11 PM
Xtnct00WS6's Avatar
Drill mod, a good bench bleed, and a full bleed to follow up should take care of that.
Old Apr 7, 2006 | 11:24 PM
bigdsz's Avatar
You definitely need to do the "drill mod". Removing the line restriction allows the brake fluid to move more freely.
Old Apr 18, 2006 | 09:28 PM
NVR_ENUF's Avatar
Just an update for whoever does a search later on and comes across this thread...
I did the drill mod... didnt help...
...so I bought a Mcleod Adj. Master, installed it... and it cured the problem.
Instant fix.... I can now slam gears as fast as I want...
You should still do the drill mod though... It'd be stupid to have it all apart and NOT do it...
