bleeding clutch
Old Apr 7, 2006 | 11:29 PM
6sphugger's Avatar
Default bleeding clutch
Where is the slave cylinder? I have searched and no one has really said where it is. I am trying to bleed the clutch and want to do the drill mod. Can anyone help me out, I am retarded when it comes to camaros.
Thanks
Old Apr 8, 2006 | 10:21 AM
Farmer2's Avatar
Go to installuniversity.com and they will have a write-up on the whole procedure. I recomend doing a bunch of research first before attemting this.
Old Apr 9, 2006 | 06:42 PM
My90Iroc's Avatar
The slave cylinder is on the input shaft inside the bellhousing. You can access it from under the car on the drivers side. You'll see the steel braded line going into the tranny (goes into the slave) and right above the line you'll find the bleeder valve for the slave cylinder.
As for the drill mod, that's done on the master cylinder which is under the hood located under the brake booster. It goes through the firewall and connects to your clutch pedal. Definitely read the article at install university listed above.
