Clutch noice...
Old Apr 10, 2006 | 09:27 PM
The Gentlemen's Avatar
Default Clutch noice...
I have a 01 WS6 M6 and when I let up on the clutch in first and reverse I hear a sort of "***** *****" sound....kinda like something breaking....so you guys can assume that I'm pretty concerned....any ideas guys?????
Old Apr 10, 2006 | 10:56 PM
FunkyTownFBody's Avatar
That's probably a u-joint or something in the rear end, not the clutch...
Jack up the rear with the car in gear and see if there is alot of play in the driveshaft. Then do it with the car in N and see if it makes the noise when you turn the driveshaft.
