Pilot Bearing Install?
Old Apr 15, 2006 | 01:33 PM
MetallicaMatt's Avatar
Default Pilot Bearing Install?
need some quick help
about ready to put everything back together
do i need to replace my pilot bearing? I don't know how I can get that out, without the "blind puller", which i don't have.
is it a must? my car has 20k on it, going on my spec 5
any other ways to get it out?
thanks!
Old Apr 15, 2006 | 02:49 PM
bump bump
or this things going in w/o replacing!
Old Apr 15, 2006 | 07:24 PM
8a8mfh's Avatar
20,000 miles it should be ok.
For future reference you can take a 3/16 to 1/4" drill bit to make a few holes through the bushing and collapse it to get it out.
Actually that works good with bronze bushings, the ones with the needle bearings inside are made of harder metal I think.
Old Apr 15, 2006 | 09:02 PM
Red's Avatar
Red
While u are there,change it.Get the puller comes right out.
Old Apr 15, 2006 | 10:42 PM
chpmnsws6's Avatar
Change it. its well worth buying the tool and spending the 8 dollars for the bearing.
