Clutch Question
Old Apr 19, 2002 | 09:21 PM
Gold Phoenix's Avatar
Default Clutch Question
Does the Star Spec Stage 3 clutch bolt-in without an adjustable master cylinder or do I still need it? Also, my car has 32000 miles on it, should I replace the slave cylinder?
Old Apr 19, 2002 | 11:19 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Clutch Question
Get an adjustable m/c and newer '01 slave cylinder with ANY LS1/LS6 clutch you install! The adjustable m/c is one of the best aftermarket parts for a LS1 M6 hands down.
Old Apr 20, 2002 | 07:45 PM
My car is a 2001 with over 32000 miles on it. Should I go ahead and change the slave cylinder?
Old Apr 20, 2002 | 07:56 PM
Postal's Avatar
Jason,
I talk to McLeod and they suggested using the 02 TOB. Is there a difference between the 02 and 01?
