704 code clutch switch
Old Apr 22, 2006 | 10:55 AM
daleal's Avatar
Default 704 code clutch switch
Any suggestions on fixiing this problem?
Old Apr 22, 2006 | 11:07 AM
keliente's Avatar
Take the lower dash panel off and have a look at the switch itself. A lot of times it's not the switch - it's the bracket that holds the switch in place. One of the cheap plastic tabs will break off and the switch will slide out of place, so it gives you that code. Mine did that so I just put a hole through it and re attached it with a ziptie, instead of waiting a week for a special order part to come in.
If its not that then it may be the switch itself which doesn't cost much. I have one for sale if you need it.
