Noise from shifter
Old Apr 23, 2006 | 09:27 PM
huskerpower02's Avatar
Default Noise from shifter
There is a faint "buzzing" noise coming from my shifter when the car is in neutral. When the shifter is in gear it doesn't make the noise. I don't know if the noise stops when the clutch is in but not in gear. I just put in a ws6store short shifter but it doesn't seem to be coming from that. Any suggestions?
Old Apr 24, 2006 | 08:55 PM
rich Z's Avatar
Was the noise there before the shifter install? If not then get some gasket paper and use it between the the handle and shifter toi supress noise.
Old Apr 25, 2006 | 01:19 AM
No the noise was not there before the install.
Old Apr 25, 2006 | 06:50 PM
jimbo98z's Avatar
It's probably just the fact that you have more metal to metal contact with the trans. I wouldn't worry about it.
Old Jun 5, 2006 | 11:24 PM
WhiteMamba's Avatar
Same thing with mine.
THere is an odd buzzing sound coming from what I believe is
the transmission.
When I put it in gear or have the clutch in It stops..
If I let the clutch out , or have it neautral it start making
a Hissing Sound. ( Slight)
What could it be?
