5th and 6th stuck
Thanks, junior If you have any mechanical knowledge, it's a very easy straightfoward repair. You can a new 5/6 synchro from D & D performance for about $100-$150.
All you have to do is pull the trans out, stand it up right, pull the end case off, and start pulling the pieces of the main shaft until you reach the synchro. KEEP EVERYTHING IN ORDER!!!!! KEPP EVERYTHING VERY CLEAN!!!!!
Good luck.
If you need any other help, shoot me a pm.
I've done this many times on my tranny and other tranny's
