Clutch Question?
Old May 9, 2006 | 04:18 PM
02 SS's Avatar
Default Clutch Question?
After I run my car hard through the gears the clutch pedal starts to engage right at the floor, it gets hard to push in and I have to push it all the way to the floor to get it into gear. Then after I drive it for a few minutes it makes its way back up to its normal spot. Any suggestions, is this normal?
Old May 9, 2006 | 04:26 PM
Tobynine9's Avatar
Mine does the same after a hard run up through the gears. If I'm not ready for it, I look like a cooze when I kill it after just looking all cool and fast.
Old May 9, 2006 | 04:31 PM
Phynix's Avatar
sounds like the master cylinder, that happened to mine when it went out, so I just did the clutch at the same time
Old May 10, 2006 | 08:30 AM
Tobynine9's Avatar
If, after you make your run through the gears, you pump the pedal, say at the next stop light, it'll come back up. You don't have to wait a few miles or anything.
