Master and Slave Cylinder
Old May 24, 2006 | 11:44 PM
KYSpeedFreak's Avatar
Default Master and Slave Cylinder
Do I have to install a new master and slave cylinder in a 99TA if I go to a LS6 Clutch Kit? I have 50K miles on the car and would like to just keep the old ones if possible.
LMK if they need changed to go to the LS6 Clutch Kit...
TIA
Old May 24, 2006 | 11:56 PM
Deech's Avatar
PR Director
The master and slave where upgraded for the '01-'02 cars and it would be better to change yours out to the '01-'02 since you are going to have the tranny out. Your hydrolics will go out eventually and you would have to do it anyways, this will just save you time. I would recommend upgrading.
Old May 25, 2006 | 07:55 AM
wrencher's Avatar
wrencher
Yep highly recommended replace the hydraulics, along with doing the drill mod.
Old May 25, 2006 | 08:06 AM
keliente's Avatar
https://ls1tech.com/forums/manual-transmission/510788-manual-transmission-faq-look-here-first.html
#7.
