Weird Clutch Feeling
Old May 26, 2006 | 07:30 AM
SonofaBish's Avatar
Default Weird Clutch Feeling
I'm sure there is something about this on here, so i'm sorry about the repitition. Car's clutch has ran great since i bought it, but the last two days taht i've really gotten into the throttle hard the clutch seems to get weird.... It still works fine, seems to grab fine, except the clutch pedal seems like its pulled closer to the floor... I've read somethign about stock clutches sticking to the floor on a lot of LS1's.... however, it had never done it to me until this week... car has 63K miles on it...
Like i said... the car still runs fine... just seems to be closer to the floor honestly... In all reality, it feels a little better to me, but it's just different, so that's why i'm concerned...
what's the deal? any ideas?
Old May 26, 2006 | 09:49 AM
OneFast97Z's Avatar
Did you do the drill mod? Did you bench bleed the slave before installing it? Then did you bleed the system after that? I suggest doing the drill mod if you havent done so and then bleed the system with a mityvac system
Old May 26, 2006 | 09:54 AM
SonofaBish's Avatar
I just bought the car a little while ago... and as far as i kown, its still the stock clutch in the car
Old May 26, 2006 | 10:52 AM
bics56's Avatar
Sup man...you need to drill mod that thing. while you are at it put some heat wrap on the clutch line.
http://www.installuniversity.com/ins...sity/index.htm
http://store.summitracing.com/partde...5&autoview=sku
I had the LS7 clutch put in and those 2 things done to mine...I am picking it up 2day so we'll see how it turned out.
