Flywheel resurfacing question
Old May 6, 2002 | 01:05 PM
Scalpel's Avatar
Default Flywheel resurfacing question
I'm gonna have my flywheel resurfaced when my RAM goes in. What technique or way should I tell the machine shop to resurface it by? <img border="0" alt="[Z06 Corvette]" title="" src="graemlins/z06.gif" />
Old May 6, 2002 | 01:48 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Flywheel resurfacing question
I just drop my flywheel off at a local driveline place and tell them to resurface it. They know me by name now since I have been in there so many times. LOL There is really nothing hard about it. Ask around and fine a reputable shop.
Old May 6, 2002 | 01:50 PM
Stick only's Avatar
As long as it is 'surface ground', that is not turned on a lathe, there is not a particular spec. The main things are a) make sure they locate the flywheel on the crank flange, not the ring gear so the grind is parallel, and b) don't let it spark out so long that the surface is glassy smooth.
Old May 6, 2002 | 03:06 PM
Scalpel's Avatar
Stick only, what should the use to mark the flywheel to the crank flange?
Old May 6, 2002 | 06:17 PM
Stick only's Avatar
It only clocks in one position so you don't have to worry about that. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 6, 2002 | 06:18 PM
Scalpel's Avatar
Is it keyed in a sense then? So that it goes on the same way it was taken off? Thanks.
