Another LS7 Installed
I went with the Fidanza aluminum flywheel and haven't had any problems. The clutch engagement is starting to rise a little, but like everyone else it was right off the floor. Engagement and acceleration is extremely smooth, no more shakes and vibration at all.
My previous clutch was a Spec stage 3 with their billet steel flywheel and it used to shake a lot at idle and when the rpms got up there. Maybe there was a balancing issue? All I can say is WOW what an incredible difference the LS7 clutch makes for basic drivability. I no longer feel like I'm shaking the car apart on start off (the spec had a tremendous amount of chatter.) With the aluminum flywheel the engine rpm's seem to rise a bit faster than they used to with the billet steel + spec clutch also.
Over all I'd say I'm a happy camper with this setup.
I also got my from Fred Beans, though the level of service wasn't what I expected. Also don't bother trying to get any shipping method other than ground. When I asked about 2 day they quoted me three times the cost of shipping (close to $200 quoted for 30 lbs.)
I got the flywheel from Gripforce.com and they were great to work with. They only charged me $30 for 2-day shipping and ground would have been free.
I am using spec 3 with aluminium flywheel too, to be honest i didn't feel any difference between steel and lightweight... how much did you pay for clutch and PP and what did you pay for aliminum flywheel?
I was charged 372 + shipping for the LS2 vette flywheel.
Something tells me the last setup wasn't balanced as this just seems so much smoother all around. No more heavy vibration from idle or putting the foot down.
LS7 Clutch and PP
LS2 Flywheel
LS6 Master cyl
LS6 Slave cyl
What else do I need for the install? I plan on doing this myself with a few friends on a hoist ... I just dont want to forget anything.
Pilot bearing? Throw out bearing? Flywheel bolts? Part #'s?
Are there any Clutch install write ups?
Thanks guys,
LS7 Clutch and PP
LS2 Flywheel
LS6 Master cyl
LS6 Slave cyl
Thanks guys,
] I was charged 372 + shipping for the LS2 vette flywheel.
I found a write up on installuniversity for the clutch install and drill mod ... shouldnt be to bad.
Any idea on what pilot and throw out bearing I should purchase? Just regular OEM parts for my year LS1?
Thanks,
Thanks,
Sorry I never changed it so I got no idea, my car has still got 40k miles
I am assuming stock replacement would be just fine if its necessaryFeel free to PM me if u got any questions about drill mod or clutch install
