CLUTCH HELP PLEASE
Old May 11, 2002 | 02:53 PM
LARRY01Z28's Avatar
Default CLUTCH HELP PLEASE
Please somebody help me. I put a new clutch in and now my peddle is really soft. when i push the clutch in its really soft. how do i bleed the brake master cylinder? or does someone know where i can find out how to do this? I have a 2001 camaro z28. thanks alot.
Old May 11, 2002 | 04:37 PM
LARRY01Z28's Avatar
Default Re: CLUTCH HELP PLEASE
thought I should tell you that the clutch works fine and i took it around the block and the gears change just fine. but the peddle is really soft and spongey. thanks again for any help.
Old May 13, 2002 | 12:44 AM
Jason99T/A's Avatar
I can shift faster than you.
Do you have an adjustable master cylinder?
