HELP Spec clutch install
Also it seems as I my have to overcome the PPsprings as they stick out much ferther than the stock one is that true .
In install university they mention leaving out the spring on the TOB could I do that with a SPEC .
I have tryied for a long time to get it in but it wont go I get like maybe 1 1/2 from the bellhousing the splines go into the clutch disk and the pp spring fingers are touching the TOB but that is where I get stuck . Any help would be greatly appreciated
Good luck.
