Noise while rolling w/M6
Old May 15, 2002 | 05:43 AM
VAWJ's Avatar
Default Noise while rolling w/M6
I have 8K miles. I noticed that when I am rolling between 10 and 30 mph in neutral with the clutch depressed I get a low popping or clunking sound. It is not the same type of rattle I hear in the garage with the clutch out, in neutral. Any ideas?
Old May 15, 2002 | 06:35 AM
2000 Camaro SS's Avatar
Default Re: Noise while rolling w/M6
The throw out bearing spinning and dragging the spring with it....If this is happening you would hear a pop from the end of the spring catching. Does the popping get faster if you give it gas while doing this?
