Flywheel Question HELP!!
do i have to buy a new flywheel or can it be resurfaced??
any help is appreciated!
Andrew
Keep in mind, as you remove material from the friction side of the flywheel, that moves the clutch away from the release bearing. Ideally you would shim the TOB the same distance as the thickness of the material that was removed from the flywheel.
Andrew
