Lt1 T56 ?
Old Jun 23, 2006 | 01:46 PM
Questsi's Avatar
Default Lt1 T56 ?
I am installing an LT1 T56 in my Conquest and I have a question about the TOB. Am I supposed to install the tob between the clutch and pp, or do i slide it on the input shaft and attach to the fork. On a few pictures i have seen it looks like the tob is installed with the pp. Sorry for any newb questions but this has been quite a venture... I might have to remove the pp again if I fffed up. Thanks
Old Jun 23, 2006 | 03:46 PM
396D1SS's Avatar
take the pp back off and install it between the clutch and pp when the fork is connected it pulls out on the pp hince the little fingers on it
Old Jun 23, 2006 | 03:49 PM
Questsi's Avatar
Crap...I hate doing things twice. Thanks for the reply!!
Old Jun 24, 2006 | 06:20 AM
V8 Supra Builder's Avatar
How about some pics of the V8 'Quest! I was looking at doing one of these before I bought the Supra, and from what I've learned here a front sump GTO oil pan will make a Gen 3 swap a lot easier. I still may do this as my next swap, I'm also looking at a Porsche 928.
Looks like the same clutch I have on my LT1 280Z.
Old Jun 24, 2006 | 07:07 AM
Project GatTagO's Avatar
Thats not a V8 Conquest..
Tell us what engine your using.
Andrew
Old Jun 24, 2006 | 09:56 AM
Questsi's Avatar
G54B
The clutch is a Spec 3+ and I got a custom Fidanza to work with the adapter kit.
Old Jun 24, 2006 | 10:00 AM
rollinna65's Avatar
35psi
Old Jun 24, 2006 | 06:42 PM
396D1SS's Avatar
sweet, did you get the to bearing in?
Old Jun 24, 2006 | 06:50 PM
Questsi's Avatar
Yes, I pulled the pp and installed the bearing from the inside. I have heard that the clip that holds the TOB in place tends to come loose and is only there to assist in the install. Is that correct??
I should have the tranny in by this weekend. I have to hammer out the tunnel a bit as the t56 is a lot beefier than the stock tranny. I just need to decide on a shifter now and get the custom driveshaft made. I can't wait to drive a 6 speed Conquest
Old Jun 24, 2006 | 09:10 PM
My bad, I read your first post & thought you were putting an LT1 and a T56 in. I see now it is just the T56.
Car looks good regardless. I don't think there are any custom driveshaft makers here that are sponsors, so I can share that I had the steel driveshaft for my LT1 280Z made at Denny's Driveshaft. Great guy, he spoke to me personally to make sure it was right. It was high quality & an excellent fit for $300.
