bleeding the clutch?
Old Jun 28, 2006 | 11:27 PM
pro2low's Avatar
Default bleeding the clutch?
where is the bleeder screw on a tremec t-56.......im have to use a mighty vac
Old Jun 29, 2006 | 12:03 AM
bray's Avatar
on the driver side of the tranny, bout 2-3 inches above the clutchcable Q/D
Old Jun 29, 2006 | 12:05 AM
BriancWS6's Avatar
On the lefthand side of the tranny, or driver side you might call it. Look for the steel braided line going from the master cylinder to the slave. The bleeder valve will be right there.
Use a deepwell socket and a 1/4 drive breaker bar to do the bleeding chore, works great. Good luck!
Old Jun 29, 2006 | 12:21 AM
pro2low's Avatar
i also heard you dont even need to if you use a mighty vac?
Old Jun 29, 2006 | 03:59 PM
Shoulder Shaker's Avatar
I have to try one of these mighty vac things. Bleeding mine was kind of a PIA.
