clutch problems HELP
Old Jul 3, 2006 | 11:42 PM
black97ss's Avatar
Default clutch problems HELP
so i drove my car last night, and it was shifting very hard. it has a mccleod clutch spec 2 i believe. and today i got in it and i tried drivin it and i found the first few inches of pushing in the clutch are very loose then the last few inches of pushing in clutch are stiff. when i start it in gear it starts to go already. so the clutch has grip. any ideas???
Old Jul 5, 2006 | 02:26 PM
Mike44138's Avatar
Could be air in the hydraulic system. Check for leaks and the reservoir level. Bleed the clutch and watch the fluid level to see if it changes. If the level changes you've got a leak. (Most likely the slave)
