How To Shift Smoother!!!!!!!!!!!
Old Jul 12, 2006 | 02:00 PM
nikeair042's Avatar
Default How To Shift Smoother!!!!!!!!!!!
When I bought the car, the guy had a pro 5.0 in, i hated it. Very notchy and loud. Now I have the stock hurst in it, and it's ok. I was wondering if there are any smooth shifting ones, like, no effort to move it from one gear to the next, nice a quite. I was thinking the hurst plus but I am not sure...any suggestions on how to make shifting easier and smoother??
Old Jul 12, 2006 | 03:31 PM
Charging TA's Avatar
I know alot of guys want the feel they get from a Pro 5.0, someones gonna come in here and tell you to get a Crown Victoria if you want smooth (it was posted as a reply eariler). The wear on a tranny will effect how easily it goes into gear, for example there was a thread where a guy was asking why his is hard to get into gear yet his buddies car that should be identical just slides in real easily.
Old Jul 12, 2006 | 03:38 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
New internals will solve most of that problem. Your shifter will have about 20% to do with it. You want a smoother shift, get an automatic transmission.
Old Jul 12, 2006 | 04:02 PM
DaGeneral's Avatar
Old Jul 13, 2006 | 09:04 AM
nikeair042's Avatar
not a smoother shift, just something that slides into gear easy. I drive manuel cars all the time and seems like these cars are just tougher. I have to actualy use force to get it into gears, where other cars I can use one finger to shift it into gears....
Old Jul 13, 2006 | 09:17 AM
I-10 b4c runner's Avatar
Check dat Clutch .........
Old Jul 13, 2006 | 10:37 AM
nikeair042's Avatar
i bought a new clutch back in january. i mean, it goes into gear fine, doesnt slip, but i guess i am used to something super easy and smooth, no real effort. When i shift, i have to feel it like "click" in 2 times then i know its in gear and wont grind. kinda weird, but i guess i gotta deal with it...
Old Jul 13, 2006 | 10:45 AM
DONAIMIAN's Avatar
Trippe cone $yncro conver$ion
Old Jul 13, 2006 | 11:37 AM
nikeair042's Avatar
what? lol
Old Jul 13, 2006 | 11:40 AM
DONAIMIAN's Avatar
The corvette T-56, and I belive the GTO T-56 uses a tripple cone syncro configuration. Its expensive for the conversion, but its a lot smoother.
BIG_MIKE2005's Avatar
Sounds like it could be in the tranny.
Old Jul 13, 2006 | 01:19 PM
nikeair042's Avatar
well, when i had the clutch put in, they said the "input shaft" or drive was a little damaged, so they sanded it down to make it a bit smoother. i have not driven another t56 car so i dont know if it feels like it is supposed to...
Old Jul 13, 2006 | 01:40 PM
BanditTA's Avatar
I had my syncros and a few shift forks updated per a GM bullentin. They filled the tranny with redline synthetic for manual transmissions. Its amazing how smooth the car shifts now, smooth as glass in all gears.
I had them put the redline fluid in after reading on the corvette forums how great it works. I had to have it ordered through a local parts store and yes it was pretty expensive but WELL worth it, a night and day improvement.
Old Jul 13, 2006 | 02:45 PM
nikeair042's Avatar
just by changing the fluid...hmmmmm...
Old Jul 13, 2006 | 03:32 PM
Turo's Avatar
Well, IMO the T56 isn't the smoothest transmission out there anyways, so I'm not sure if you have a notchy transmission or just aren't used to it.
I drove a Prosche the other day and DAMN those trannys are smooth!
Old Jul 13, 2006 | 03:47 PM
nikeair042's Avatar
yea, i would love to drive another trans am or camaro and see what it feels like...maybe its normal, idk...but as long as it goes into gear and drives fine, im happy i guess lol
Old Jul 14, 2006 | 07:33 PM
N3V3RL8T's Avatar
welcome to the "my shifter clicks twice before going into gear"club. I know what your talking about though I have the stock hurst and a t56 with 10K miles on it and feels just like the old one with 95k. But a friend of mine has a 99 with the stock shifter and that thing feels like a honduh whilst rowing threw the gears.
Old Jul 17, 2006 | 12:22 AM
ssmaro's Avatar
My shifter feels the same way, just seems like it doesn't want to come out of gear or go into gear without using a little force. Gets very annoying after a while too. The sad part is no one on this website has a positive idea of what the problem is, or how to fix it
Joel
Old Jul 18, 2006 | 07:17 AM
BanditTA's Avatar
I'm telling you guys change the fluid, i was the first to say there is no way fluid will make that much of a difference. It does, night and day. Do a search on some of the corvette boards thats how i found it.
Old Jul 18, 2006 | 02:53 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
4qts of Redline is about 60$ lol!
