BellHousing stuck to the block
Old Jul 18, 2006 | 12:51 PM
2001blackta's Avatar
Default BellHousing stuck to the block
changing clutches today and I can't get the ballhousing out.using the steps on installuniversity.com I have removed all 8 13mm bolts and it still feels solid. am I missing something?
Old Jul 18, 2006 | 01:04 PM
98turbls1's Avatar
Yeah!!! It's called elbow grease... Those things get stock on there REALLY good.... Just get a big flat head screwdriver and wedge it in about every 4 inches...It's going to be a little tough but the more that you work at it the easier it'll be...
Old Jul 18, 2006 | 01:30 PM
ws6charged's Avatar
no no no just get on the shifter part of the tranny under there and rock that bitch till it breaks loose! trust me it works good.
Old Jul 18, 2006 | 01:49 PM
BIG_MIKE2005's Avatar
Man, just pull & wiggle. Also tap a flathead screwdriver in around a few different spots. Be careful not to break or crack the housing.
Old Jul 18, 2006 | 02:19 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Pry bar works great. Just don't place it up against the starter.
That is ignorant. You should be taking the transmission off the bellhousing before you try and get it loose. Your guide pins are gonna make it tough enough as it is. Just take the transmission off the bellhousing. Dont yank on your shifter cup. What do you do when it finally comes loose? Let it fall on the floor? or tilt off the jack? You are not going to be able to hang onto it if it accidentally "pops" out.
Old Jul 18, 2006 | 02:34 PM
Gary Z's Avatar
WD-40 in the gap near the alignment pins (3 o'clock and 9 o'clock) worked wonders for me.
Old Jul 18, 2006 | 03:45 PM
Technoman64's Avatar
WD-40 and kept moving it around worked for me.
Old Jul 18, 2006 | 03:51 PM
2001z's Avatar
Use a screwdriver in the crease that is there for that reason and wiggle it around some it will come loose
Old Jul 18, 2006 | 04:40 PM
Phlip00WS6's Avatar
Just dont hit your flywheel with the screw driver/prybar while your prying on it!!!
Old Jul 18, 2006 | 06:13 PM
NVR_SPDS's Avatar
Just pry it out, like everyone said. Make sure the screw driver/prybar isnt behind the flywheel, or youll be in for ALOT more work then you have to. There are 2 large dowel pins, one on either side (driver and passenger) and they hold like a bitch. I used some anti-sieze on mine, when i replaced the tranny, and ill be pulling it again soon, so ill know if it worked or not.
Old Jul 19, 2006 | 11:53 AM
Thanks for the info everyone.Next time I change a clutch I will remember that pry bars are youre friend .
Old Jul 19, 2006 | 02:35 PM
N4cer's Avatar
Haha I just went through this 2 days ago. Beating on it with a rubber mallet works to get it started, then pry and pray.
Old Jul 19, 2006 | 02:43 PM
Boodyrider's Avatar
Pry... with EXTREME caution. I'd rather use just a rubber hammer and lube the pins. That housing is just cast aluminum, and you don't want to break pieces off.
Hint: putting it back on, polish the guide pins with emory cloth or a 3M pad, and wipe with antisieze. Makes next time a LOT easier.
Old Jul 19, 2006 | 03:01 PM
LS1powerhouse02's Avatar
ahh yes.....the sorry *** bellhousing.....i went through this the first time i pulled my tranny. Just make sure you lube the **** out of those dowel pins before you put them back in. It will make it easier next time believe me! I just pulled my tranny for the 3rd time and it came out easy as pie!
Old Jul 19, 2006 | 03:03 PM
chadtx01's Avatar
The more you do it the easier it gets.
First time was a major pain in the ***.
Second time, went a little faster.
Third time was a breeze.
Fourth time I dont think I ever opened my eyes.
