Clutch or Tranny problem?
Old Jul 25, 2006 | 08:53 PM
Zentenk's Avatar
Default Clutch or Tranny problem?
Hello, I have problems. Tonight I was going from 40 in 2nd and went to 3rd and there was nothing (as in it were in neutral), then I put it in neutral and she was shaking and I pulled off the road, made some calls. Then I drove her back normal. What's up? Also it wouldnt go into gear at first (sitting there w/ engine off) I just kept going through all the gears till it would eventually slip in. I am putting a new clutch in soon but maybe also need Transmission? I called my bro before driving it and he said it may be loose bolts because he had it happen to him having a shake in Neutral.
I thought it was the Clutch, it would feel really sticky going into gear after driving or if it is like a 90 degree day out.
Help please!
Thanks!
Old Jul 25, 2006 | 09:39 PM
z28drag's Avatar
its hard to tell, but it sounds like the clutch/slave, if tranny goes it will not let u in 85% of the time...
Old Jul 30, 2006 | 04:45 PM
Zentenk's Avatar
OH thanks, sorry I forgot all about this post. Anyways, I am getting my clutch changed over the next couple days... (it is hades outside!) so we will see after the change.
