need a rebuild
Jacked the rear up ran through the gears shifts fine , dropped the weight on it and i thinks its the rear end
the car starts, goes in gear moves out and shifts fine at idle throttle, if any throttle is apllied ,the **** hits the fan ,sounds like broken gears . virgin car, i babied it and this happens . unless the previous owner ran the car hard which i doubt because the dude ran 87 octane in it . I need some help here
15,000 miles and it just started today. Sounds like its 'poping' out of gear, just normal driving it, with a big grinding noise. Anyone ??
All the needle bearings in my stock pilot bearing had fallen out and it made the exact noises you decribed . check that first . I replaced it with a solid bronze one . $10.00 dollar part can mess up your day
