Low on fluid?
Old Aug 15, 2006 | 12:54 AM
Bad Blu Formula's Avatar
Default Low on fluid?
Lately i've been noticing that i'm having some notchy almost grindy shifts. Its not a consistant thing either. Now, recently the slave and clutch were replaced so i know it probably has nothing to do with that. The tranny was shifting fine after I had the slave and clutch replaced two weeks ago, but it wasn't until about 5 days ago that i've been noticing the funny notchiness and the feeling of a light grind. Could it be possible that my tranny is low on fluid causing this? I only spilt like 2 or 3 oz. of fluid when we did the clutch install too.
Old Aug 27, 2006 | 10:30 PM
Arcolog2's Avatar
Would also like some help with this, I started noticing the pedal feel like not completely dis-engaging, grinding gears on normal shifts. And really hard to go through the gears when "givin' her the beans"
I popped the hood and found the clutch fluid resorvoir was empty, whoops...
I added fluid but is there anything else I should do to help it out? it's an 02.
Old Aug 27, 2006 | 11:27 PM
Well if the resorvoir was empty then theres a good chance you got air in the system. Just refill and bleed the system accordingly.
Old Aug 28, 2006 | 06:40 AM
calhoon's Avatar
You will need to find the place the fluid leaked out as well.
