Ram HD. Need shim??
Old Aug 27, 2006 | 05:01 AM
SPECIALIZED STAINLESS's Avatar
Default Ram HD. Need shim??
I was reading that you need to install a shim behind the slave. Is this true. What would happen if you didn't. Thanks for any responses.
Old Aug 27, 2006 | 09:06 AM
BTLFEDSS's Avatar
I put the shim in when i did mine
BTLFEDSS
Old Aug 27, 2006 | 12:24 PM
What does the shim do exactly? I also read that if you have an adjustable master cylinder than you don't need the shims...
The reason I'm wondering is because I have the Ram HD clutch ready to go in, but I don't know if I need the shims or not. Please help
Old Aug 27, 2006 | 10:46 PM
bump..........
Old Aug 27, 2006 | 11:25 PM
The PAT WS6's Avatar
wat did u do with ur flywheel did u resurface it. i would go ahead and put it in i did it when i did my ram
Old Aug 27, 2006 | 11:28 PM
Yeah, it's resurfaced. That's the thing, I don't have a shim. I'm planning on an adjustable master cylinder so I think it should be fine without the shims...
