Help Need Info
Old Aug 29, 2006 | 12:56 PM
C-17ss's Avatar
Default Help Need Info
Thanks up front......I have a spec stage 2 and the flywheel has been cut. It has about 5000 miles on it and now i'm having a shifting problem . The clutch also make a lot of noise. It is had to shift and get's harder every time the car gets warmed up . It's even worse when it gets hot. i have talked to spec and they say that it's every thing but the clutch. I have bleed the hell out of the hydro but no help.
