help.....need ram shim advice
i got everything in the car and just shimmed the clutch with one shim.
clutch is real hard to push in and when i have the clutch pushed in and put it in gear the car roll's a little.like its inguaging.
i also cant get it into reverse.
im gonna pull everything apart and reshim.
what shims can i use?
do i have to use ram only?
what size?
how many shims should i use for street?
should i shim the slave cylinder?
everything was working fine in the car it came out of.
im gonna work on it somemore in the mourning.
any tips?
