how much movement in the shifter is normal?
Old Sep 18, 2006 | 07:39 AM
SpringtowN's Avatar
Default how much movement in the shifter is normal?
i was wondering when i get on it in first and second my shifter moves to the side about a half inch or so?? is this normal.. it bothers me for some reason enough for me to change my tranny mount to poly... while i was doing that i found the broken torque arm bushing so i replaced it...i just had my motor mounts replaced so i doubt this is the prob...is this normal ??.....is there anything at all in the rear end that could keep breaking mounts?? i have gone through a few both motor and trans....i dont run slicks and i have not been getting on it hardly at all somthing just doesnt feel right with it any help would be great?
Old Sep 18, 2006 | 10:32 AM
calhoon's Avatar
Sounds normal to me. That totque arm bush could have been a big contributor.
Old Sep 18, 2006 | 10:38 AM
Ericbigmac83's Avatar
Mine does the same thing, i keep meaning to look to see if my mounts are ok. some movement is normal though
Old Sep 18, 2006 | 10:41 AM
SpringtowN's Avatar
hope so...no its off topic but how you like that corsa exhaust ericbigmac been thinking bout getting one.....
Old Sep 18, 2006 | 10:42 AM
SpringtowN's Avatar
Also is there anything else in the rear suspension or rear axle that could contribute to this movement.....???
Old Sep 18, 2006 | 11:43 AM
1998z28ss's Avatar
No I'm pretty sure its all between the tranny mount and torque arm bushing. Ive got energy suspension on mine and it still moves maybe 1/4 to 1/2 an inch when you hit the throttle.
Old Sep 18, 2006 | 06:47 PM
SUTTERERMAN85's Avatar
you need a poly mount. energy supension at autozone for like $20 mine used to love a **** load and bounce like a titty dancer at idle
Old Sep 18, 2006 | 09:58 PM
1998z28ss's Avatar
Whats wrong with the energy suspension? Just curious...whats the difference between that and a poly mount?
Old Sep 18, 2006 | 10:02 PM
nothing is wrong with energy suspension. they are made out of polyurathane hence "poly"
Old Sep 19, 2006 | 12:26 AM
1998z28ss's Avatar
OK I thought you were ******* it saying I needed a more expensive poly
Old Sep 19, 2006 | 02:31 PM
So what bushing do we need?
And yes, that was slightly off topic, but I love my Corsa exhaust, its nice and quiet cruising around and sounds nice and mean when i get on it. I'll let ya know how it is once i get headers put on.
