boiling clutch fluid?
Old Sep 19, 2006 | 11:13 AM
pro2low's Avatar
Default boiling clutch fluid?
could anybody help me and explain the effects of this...i think i may have this problem!!
Old Sep 20, 2006 | 01:50 AM
pro2low's Avatar
anybody ttt
Old Sep 20, 2006 | 08:18 AM
warp10's Avatar
Boiling creates air in the line. That's why old oil is not so good. It gets contaminated with water and boils at a lower temperature.
air=bad
Do you have headers? Does the line go close to it? Did you remove the heat shield?
Old Sep 20, 2006 | 09:02 PM
pro2low's Avatar
no i still have the stock manifolds i heard it happens with those too....it was weird i replaced my hydraulics and it was fine for over 2 months...then i was driving it one night and it ground 2nd gear and was harder to shift so i opened the resivoir and it was completly empty? i have no idea what happened there arent any leaks as far as i know there isnt any fluid dripping
Old Sep 20, 2006 | 09:06 PM
Mike44138's Avatar
Probably a blown slave. Fill the reservoir and check for fluid dripping from the slot in the bellhousing.
Old Sep 20, 2006 | 11:40 PM
pro2low's Avatar
havent seen any fluid dripping at all, ill be under the car tomorrow to fix my exhaust (it is rattling) ill get a closer look then ill keep u updated.
Old Sep 21, 2006 | 10:07 PM
pro2low's Avatar
no dripping at all undercar!
