LT1 t-56 to BBC
Old Sep 19, 2006 | 03:00 PM
BLUE72CAMARO's Avatar
Default LT1 t-56 to BBC
I have an lt1 t-56 which I am going to be putting behind my bbc. I have all the stuff to make it work with a stock bellhousing but i would really like to go to a blow proof bellhousing and a push style clutch. Does anyone know if this is possible to do? I assume that Mcleod makes the parts needed but I am waiting to recieve a catalog from them to find out.
Also who do you guys reccomend to do upgrade work on the t-56 to make it stand up to 490hp and 505ft/lb?
Old Sep 20, 2006 | 08:29 AM
onebad82z's Avatar
You may have better luck on nastyz28.com as far as the BBC/T56 setup goes.
As far as upgrade work..check out t56rebuilds.com (joe)
Old Sep 20, 2006 | 12:33 PM
SUTTERERMAN85's Avatar
to have the tranny rebuilt you need to get ahold of amber or joe at T56rebuilds >> sponser. they have great turn around time and top notch quality and customer service
Old Sep 20, 2006 | 02:23 PM
Alright I am already on nastyz28.com same screenname there. Only one person has really had any advice at all for me on it over there.
As for the upgrades, I talked to amber last night and I am going to buy a 45 gallon rubbermaid container tonight.
Old Sep 22, 2006 | 01:15 PM
analyte's Avatar
go here:
www.t56kit.com and then call them!
They are the one's you want to talk to. Thay have already done the legwork and can sell you a kit with all the special brackets, trans crossmember, and the modifications needed to get it to work in your Camaro.
Kerry
Old Sep 22, 2006 | 01:28 PM
Originally Posted by analyte
go here:
Kerry
I will give them a call
The trans has already been in the car with stock bellhousing and hydraulics. I am just wanting to change to a push style clutch instead of the excessively expensive pull style lt1 clutch.
Old Sep 22, 2006 | 03:02 PM
calhoon's Avatar
Sounds like what you are really looking for is an LT1 to LS1 system swap. Do a search as there ore many posts on that.
