clutch squeaking!!!!
Old Oct 8, 2006 | 11:19 AM
blacksskid07's Avatar
Default clutch squeaking!!!!
Hey guys I was on ym way home last night and everything was fine until I got into my neighborhood and came to a stop with the cutch in, i went to go and pit it in 1st but it wouldnt go and then they rpm's went down like i had it out and it wa abou to stall. I let the clutch out and the car stalled. I turned it back on and drive him and all was good. Now i just went to the garage and pressed the clutch in but now it squeaks, ANYONE HELP ME??
Old Oct 8, 2006 | 01:55 PM
Krab's Avatar
Have you checked the fluid in the reservoir? Have you recently swapped the clutch or are you on the stocker?
Old Oct 8, 2006 | 04:25 PM
the fluid is fine but the pedal has gotten a little softer, and i dont know if its the stocker, the car has 80k on it. im taking it to the shop this week.
Old Oct 8, 2006 | 04:39 PM
RiceKilla's Avatar
Usually it means the master is going bad. I had this problem on my old car where it started squeaking, eventually it got worst.
Check for leaks from either of the cylinders.
Old Oct 9, 2006 | 10:44 AM
Krab's Avatar
Do as RiceKilla said and bleed the hydraulics while you're at it. See if that fixes the problem.
