Squeaky Clutch (is it slipping?)
Old Oct 12, 2006 | 12:18 AM
02BlackOnBlackSS's Avatar
Default Squeaky Clutch (is it slipping?)
I have a Ram Powergrip HD clutch w/ Mcleod adjustable master cylinder with the drill mod (all of this came with the car), and when I first start up the car and go to take off, the clutch squeaks right before it engages. It doesn't do it after I have taken off from a stop 2 or 3 times. Can anybody diagnose my problem?
Old Oct 12, 2006 | 06:54 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Sintered iron friction material, correct? (or at least something close)? They are known for squealing like a stuck pig - mine did it from time to time, but when I pulled the clutch after 25k miles or so, it looked like it could have gone another 25k easily.
Old Oct 12, 2006 | 02:14 PM
Hugger Z's Avatar
I agree with Steve. The friction material if agressive most likely has metal particles. These will make noise. Same reason why semi-metallic brake pads make a ton of noise. You are just hearing the metal on metal noise until it fully engages.
Old Oct 12, 2006 | 04:49 PM
Well that is a big sigh of relief, one less thing to buy. I have noticed that it changes for different temperatures also, but as long as its ok, then I can live with it.
Old Oct 13, 2006 | 12:18 AM
Avengeance's Avatar
Mine does the same thing when cold.. SPEC3 and Fidanza Alum FW. Mix that with the chatter and its really annoying.
Old Oct 13, 2006 | 09:20 AM
Stick only's Avatar
Correct guys, the 900 series sintered iron will squak a little when cold. If you ever go to the races and see the pro cars, they do it too!
Mike
