need help please
Old Oct 20, 2006 | 09:36 AM
black01 WS-6's Avatar
Default need help please
I just installed a spec stage 3 and i cant get the hydralic line plugged bak in to the slave cylinder is there a trick to it my pedal is solid right now with it unconnected is this right i also had the master cylinder off if that would cause any problems
Old Oct 21, 2006 | 01:15 AM
Mike44138's Avatar
With the slave disconnected you should not be able to push down the clutch pedal. Take a look inside the fitting for the slave cylinder to make sure the metal tabs inside the fitting aren't all bent up or mangled. It helps if you pull the plastic sleeve around the connector all the way up away from the slave so that it's not interfering with the connector when you push it in. Also it can take a little muscle to get the connector engaged.
Old Oct 21, 2006 | 08:11 PM
thanks i finally did get it had to loosen the bleeder valve on the slave and it popped right in then i bled it and its fine ,
By Brett Foote | 2026-06-04 05:00:17
