cags/skip shift install help?
Old Oct 21, 2006 | 01:41 AM
Ripper415's Avatar
Default cags/skip shift install help?
Hey, I just got a skip shift eliminator and was wondering if i'd need to unplug the negative battery terminal to install it? If I put it in without disconnecting the battery, will it still disable the annoying skip shift feature?
Old Oct 21, 2006 | 02:03 AM
LS1Lust's Avatar
I don't see why it wouldn't. From what I understand all it does is go between the solenoid and the wire. Don't see why you would have to disconnect the battery.
Old Oct 21, 2006 | 02:04 AM
NoGamesLS1's Avatar
I did not disconnect my neg. They say that for a disclaimer
Old Oct 21, 2006 | 08:00 AM
calhoon's Avatar
Also, there would be no power delivered to the solenoid while you are under there, assuming you do this with the car stopped.
Old Oct 21, 2006 | 12:37 PM
mcG's Avatar
mcG
i did not unplug the battery either. just put it on ramps, and when it cooled down i put it in and started it like normal. no problems at all.
