STiILL CANNOT SHIFT AT HIGH RPM
Old Nov 1, 2006 | 10:13 AM
wilddawg's Avatar
Default STiILL CANNOT SHIFT AT HIGH RPM
I replace the master and slave and drill mod with 02 gm parts and bleed the system. At high rpm the clutch sticks to the floor and wont let me go to the next gear. I also rplaced the throw bearings the clutch have about 25000 since replaced but not slippig tomy knowledge car is 384hp rwh and 378tq. What can I do is the clutch going again or the system still has air
Old Nov 1, 2006 | 10:25 AM
LS1powerhouse02's Avatar
if you clutch is sticking to the floor it sounds like you probably still have air in the lines. How did you go about bleeding your hydraulics?
Old Nov 1, 2006 | 11:18 AM
wilddawg's Avatar
I remove the input from the old slave and insert ir on a bleeder syringe then I back bleed the system and then bleed the slave cylinder. any suggestions would greatly be appreciated
Old Nov 1, 2006 | 04:16 PM
did you make sure there was always new fluid being poured in? I'm sorry if that doesn't pertain to the way you did it, but here is the way i did it. While i had the tranny out i hooked up the new slave then opened up the bleeder and let it gravity bleed. All the while i had a buddy up top with a bottle of brake fluid making sure the reservoir was always full. If you let it get too low it will end up letting more air into the system. I hope that helped someway. If not i'm sorry and hope you get it figured out.
Brent
Old Nov 1, 2006 | 09:21 PM
wilddawg's Avatar
I think you are right it might have some air still
