which clutch fluid?
Old Nov 4, 2006 | 09:35 AM
TheLS1Kid's Avatar
Default which clutch fluid?
what kind of clutch fluid do you guys use? DOT3 or DOT4? is the boiling temp. the only difference between the two? thanks
Old Nov 4, 2006 | 08:12 PM
black01_WS6's Avatar
I use dot 3 but when I change the fluid out next time I am going with DOT 4. It doesn't really matter as long as you have at least DOT 3 in there.
Old Nov 4, 2006 | 09:16 PM
Ryan02SS's Avatar
I use Valvoline Synpower DOT IV. It has a higher boiling point than regular DOT 3. Something around 425-450 vs 300 degrees.
Old Nov 4, 2006 | 09:49 PM
SOMSS's Avatar
Synpower user here!
Old Nov 5, 2006 | 08:36 AM
TheLS1Kid's Avatar
i'm gonna go with DOT4. thanks guys
Old Nov 5, 2006 | 08:51 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I use Ate Super Blue (Dot 4).
